Just wondering if anyone has any fore knowledge or opinion on the Precision SP6262 Turbo.
Im about to purchase it as a direct bolt-on replacement for my CT26 60-1 (cant go T4 for another 2-3 years due to other upgrades planned). Everything looks good on it, but finding other people who have slapped this on a 7MGTE isn't easy.
I considered the Boss Sr., but this one looks like it may be just as good and I can still keep my 3" DP and stock manifold.
(quick rundown of current engine: Rebuilt 7MGTE with 1.2 Cometic HG, ARP studs, Wiseco Forged Pistons, 550 injectors, Lexus AFM, DM CXracing 7M Intercooler upgrade, AFPR, AEM Uego Wideband, HKS EVC-S boost controller, full 3" exhaust using HKS 3" catback and Raptor Racing 3" Divorced (reintegrated) Downpipe with integrated turbo elbow)
I want to purchase this turbo, stabilize the car and then go full standalone with a HKS Fcon Vpro 3.3 (7M chipped) and various sensor upgrades and additions.
Anyone know of a SP6262 running on a 7M this way as the CT26 replacement? (pretty sure there are 2 people here considering or in the process of doing the same thing)
Should also mention, I talked to Sound Performance and they are now only being sold with dual ball bearing setups. There is an option for a STD or HP actuator. Not sure what to base the choice on for the actuator really.. I doubt I will ever want to run higher than 20 PSI on my current setup and the HP actuator is for 18-30 psi. Pretty sure I should just run with the STD actuator (12-25 psi) as I don't see ever topping 25 psi.
There may be a different reason for choosing STD or HP that I haven't figured out yet.
No idea about AR on the turbo and from my reading (and I could be totally wrong) I don't think that it matters on this turbo because its limited due to the stock manifold DP and internal wastegate. I am aware that I will have to fab the oil lines and it is a waterless turbo (dual ball bearing), plus I will have to deal with the intake pipe and already upgraded the intercooler, so its a matter of mating pipe1 to the turbo. 62 mm exducer and 62 mm inducer seems to be nice size but no idea about overall housing and flow on this turbo.
I find the CT26 60-1 a bit restrictive... am I going to run into the same issue here? All I am trying for is a nice solid 350-400 rwhp MK3 without my current boredom after I get a boost spike.
All input is accepted!
