Personally I wouldn't use it submerged it's not designed for that...
I have never seen a single valid test done on these replacement lines/fittings showing any improvement over the stock hardline, I ran stock with 0 issues.
Not saying this is your issue, my guess is it's touched a bearing at some point, possibly low Oil low pressure or surge, this in turn will let the crank pick up material from the bearing, this happens a few times it's easy to end up with excessive clearences and there goes all of your hot idle pressure.
Don't buy into the high flow/low pressure bullshit myth, it's simply far too many leaks for the stock pump to keep up with...
