3p141592654 said:
IPT will rebuild your A340E for $2875. (They say it is good for 10s in the 1/4 mile).
You can buy the parts alone for about $1k from them.
That's where I had my auto built...they know what they are doing. They are located in Jersey.
http://www.importperformancetrans.com/
Stock, an A340E is good for about 350 HP...even then, how long it's going to last is questionable if it has a lot of miles on it. After IPT got done with mine, it would bark 2nd gear...don't expect the uber smooth shifts like a stock A340 when IPT gets done with it
BTW - I also would get a new oil pump and shim the relief valve 2-3mm with washers. I would also get rid of the stock filter head and convert to a thermostat controlled cooler circuit and remote filter head. Doing both will improve your oil pressures significantly
