Some pics of blown MHG with ARP studs, any ideas why?
SC61 MK3
316
FL
hvyman;1669491 said:
What are you tuning with? Do you have egr?
No egr, been like that for 6+ years. Do you think it was runnning to lean? I had the boost turned down to 12psi and sometimes a max of 14psi because I went back to the stock 440s/afm with a walbro, afpr and fcd. It would run right around 12:1 a/f ratio under full boost
SC61 MK3
316
FL
spikesnstuff0905;1669583 said:
Big single with stock 440's at 12psi? No... of course you weren't running lean...
I have a wideband, it was around 11.5 to 12.0 a/f under full boost if thats lean to you
Egr wouldnt matter at wot only cruise and most importantly part throttle up hills. Could be something thats happened over time and then boom.
Could have had a lean spike under boost tho that you might not have seen if the injectors werent up to par. Eh tho.
