soarer and supra ecu diffrences???
meet07
49
Wake Forest
I think it would suit me best to get a Soarer motor/tranny set since im putting it into my 89 240sx. But there doesnt seem to be much info on the swap. But I have maybe 2 diffrent pinout diagrams?? I was wondering if the ecu's are diffrent as far as the main components functioning correctly.
tissimo
Stock is boring :(
Melbourne, FL
A soarer would be better since it has the extended shifter housing (assuming 5spd). As for the body pinouts they're plug and play with a SC300, so just get the SC300 EWD and have at it.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
the 1JZ from the supra is limited to 117mph, so why would that be "screwing you?"
just get a SCD just like everyone does in the supras.
Jostar:: Yes we believe that the Soarer ECU's have a better timing map. they have the Timing Modifier unlike the JZA70 ECU's
meet07
49
Wake Forest
So which one is limited???
Reaper: your saying its the supra thats limited.....
Tanya: Saying the Soarer is limited......
At they both limited???? Whats the purpose of having a twin turbo 6 thats limited up top.
Tanya
1,851
Naples, FL
I believe (someone correct me if I'm wrong) all true JDM production cars are speed limited to 115mph. I know this is at least true for the MZ12 Soarer, and have heard it's true for most other cars there. Sort of like the 280hp limit they had awhile back. This is why I see having a JDM ECU kind of pointless unless it is absolutely necessary. There are ways to trick the ECU so that it's not limited, but I couldn't tell you how.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
Traffic speed advisory limitation: 180kmh
Gentlemen's output power agreement: 280chp
More loosely followed obviously then back when they were first made, however they were and are still in effect for the most part.
Tanya
1,851
Naples, FL
The Reaper;914770 said:
Dylan hit the nail on the head
Supra and Soarer and Aristo's were speed limited to 115-117 mph.
I thought I had said it first :icon_razz
cbutler
218
Regina, SK
yep, my jza70 is limited at 180kph, but $100 for an HKS SLD to fix that.
Not that you need to go that fast very often anyways.
7sins
Seminole, Florida
I know one thing, the speed limiter is not a big deal. For example my 240sx there is a little yellow wire that controls the 118mph speed cut and all you do to remedy it is yup just cut that lil puppy and you're off. Then if yours is more complicated than snipping a little wire, buy a speed cut defenser and you're off.
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
I'm going to be doing my 1j swap soon, so should I get the soarer ECU because it has a better timing map and doesn't loose resisters like the Supra ECU? And if so, I should use the same harness?
meet07
49
Wake Forest
Here we go:
That sure is a sigh of relief.....Thankxs cbutler!!!
