I learned that you add water to the battery when you're filling it up to dilute the acid, but thats just me.
Doward said:Keep in mind, the water itself will react with the acid to help break down the actual acid into weaker acid.
It's Sulfuric acid in the battery, right? Well, the problem with that, is a) it's one of the strongest acids known and b) when it breaks down from H2SO4 into HSO4- and that HSO4- is STILL acidic, so it breaks down into SO4-2 (damn, I don't know how to get the sub and superscripts working)
Either way - do it once, and do it RIGHT - if you can't do it right, then don't do it man - it's not worth the consequences!
Pics of the carpet now?
CampbellsChunkySoupra said:ouch. shitty luck for you. im running through a phase of that too. i would definatly look into those ultra small racing batteries. i know alot of batterie relocations go to those. i cant think of the brand of them off the top of my head though.
suprabad said:I have yet to move my battery because I am afraid of the possibility of acid fumes inside the car. If the battery or alternator decided to short or worse...I can't picture it being too good for you. Plus, don't batteries vent noxious fumes as a matter of course?
Am I worrying about nothing? Unfounded? Breathing battery acid fumes...too scary!
Can someone knowledgeable on this subject sort me out on how this can be safe?
Shytheed Dumas said:If you are 100% efficient in neutralizing the acid, you would need exactly 51% of the total weight of acid spilled in baking soda (sodium bicarbonate) to stop the damage given a typical battery acid strength of 30% sulfuric acid and this chemical equation:
2 NaHCO3 + H2SO4 ---> Na2SO4 + 2 H2O + 2 CO2
So for each lb of battery acid spilled you would need just over half a pound of dry baking soda to fully neutralize it - no matter how far you dilute it.![]()
IJ. said:Fuzz: It wasn't an Optima it was a standard lead/acid battery.
The Optima's are Gel so don't vent until 15v.
IJ. said:On a quiet night you can hear his Mk3 dissolving![]()
\\Shytheed Dumas said:If you are 100% efficient in neutralizing the acid, you would need exactly 51% of the total weight of acid spilled in baking soda (sodium bicarbonate) to stop the damage given a typical battery acid strength of 30% sulfuric acid and this chemical equation:
