After 10,000 miles, 4 of 6 Pistons were like this. And why would this be Detonation caused (if so). Looking to go Forged. Any Help Anyone?
Robert
Joel W. said:4 of 6? Something went wrong for sure....
jdub said:18 psi on pump gas? Do you know what your AFR's were at full boost? You know where i'm going with this...right?
supraguy31 said:Full Boost AFR were between 11.2 to 11.5
Detonation maybe is where you are going? I cant get anything any Better here in El Paso. 91 Octane is the Highest that they sell
supraguy31 said:Jdub, You hit it on the Money. My Builder and his Ultimate Wisdom Had the Head and Block Decked and then Decided to reuse the Toyota Stock thickness headgasket. I found this out about 2 months after that, I jusr recently bought a 2mm MHG to replace it since I was doing a Rod Knock Fix. Now Im glad that I did check the Pistons and Decided to put new rings in.
Do you think that since he reused the same factory HG again and with the head and block being Decked that this is what caused this. Low boost was set on 1 bar and High boost was set to 1.25 bar. Yes, I do use this car at the 1/4 mile Drag strip once in a while so there has been times that I used the 1.25 bar setting.
Robert
Doward said:Were the rings properly gapped? Hmm?? WERE THEY?!
