so I have this differential
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
if you want to know the ratio, just count the teeth on the ring gear, and divide by the teeth on the pinion. For example: 41 teeth divided by 10 = 4.10
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
IJ.;1067877 said:
See how the centre is enclosed?
There's a bunch of small worm gears in there.
The Diff you have is a single wheel "open" centre.
gotcha ...:biglaugh:
so were there certain yrs that got them, or just certain countries ?
or was it just a luck of the draw that when you buy a supra it has one ?
Will
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
starscream5000;1067916 said:
I'm thinking that none came in American supras unless imported from Japan from a car there, but I could be wrong... :dunno:
How much did you pay for that?
60 bucs an 30 for shipping, I was told it had about 65 K miles on it an came out of a 90 turbo manuel... with LSD
ohh, so looking at those pix, how can you tell if its a LSD ?
Will
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
IJ.;1068095 said:
Will: Usually 4 pinion gears and Clutch packs is the giveaway.
hmm, I am guess you mean 4 pinion gears are the smaller gears that are like 180 degrees from each other,,,, the ones that spin when I spin where the axles connect too ? the smaller ones ..
an the clutch pack is that large gear ?
sorry today was the first time I looked into a differential ...
Will
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Will, that is not an LSD :(
The large gear is the ring gear, it is turned (driveline side of the diff) by the pinion. Count the pinion teeth and divide into the ring gear teeth to determine the ratio. Im guessing you didnt get what you paid for.
if it was an LSD you would see something that looks kinda like this:
note the spring looking things in the area that you have basically a set of 4 gears? Not the best picture but I was too lazy to find better. If you paid for an LSD you did NOT get one and should probably file an ebay claim.
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
well thats a mother fucking Bitch, if it aint a LSD
Will
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
starscream5000;1068648 said:
Look on the bright side, you can still get your supra up and running for under a $100.00. Just use it for now until you find the real deal ;)
yea man ! :biglaugh:
still gotta get it inspected, an the guy knows I have a straight pipe in the cats place witch doesnt mate up 100 % so he knows theres a exhaust leap ... an have to find my passenger front side marker to put on to pass inspection... ,
Will
