Snaping noise when i turn the wheel
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Its easy and quick to do.
Jack up car
remove wheel
turn steering to full opposit lock
use a flat blade screw driver to remove what is left of the old one
push on new one
straighten wheels
replace wheel
lower jack
Repeat on other side
7MGTEsup
Jun 14, 2005
614
England
albo_bizak;955117 said:
but the parts that we need to replace are they only a dealer iteam or can we buy at the local parts store
Dealer only, I think I paid about £3 each so there not expensive. Its just a plastic mushroom that goes over the lock stop bolt.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
one more quick question. does the grinding/snapping noise mean damage is being done to parts, or are two parts just squeaking against each other?
7MGTEsup
Jun 14, 2005
614
England
Its basically a bolt head rubbing against a dished metal plate thats about 1" square. Its not really doing damage so to say unless your bouncing off the lock stops hard all the time.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
For those of you asking what parts are needed.... ugh.
Read page 2 of this thread and IJ will tell you EXACTLY what part you need from toyota. ;)
THANK YOU IAN!!! I had looked at that diagram for 5 mins easy and just thought that was a nut or something. ::dunce::
<<<Ordering that part later today. :)
Asterix
Lurker of Power
Vienna, VA
It's usually the steering stop cover, but...
If the bolts that hold the caliper bracket to the spindle are too long they'll touch the rotor and make a nasty noise. If they're just the right length, you'll hear nothing except at large steering angles or going fast around a corner.
That one took me a while to find, right after I bought the car. Somebody used the wrong bolt, which was just a little too long. I ground off 1/4" and it's been fine ever since.
Asterix
If the plastic covers have been worn through for awhile it's a good idea to replace B and C on each side as the bolt head will wear a little and the new cap will be unsupported.
Should only be a couple of bucks from the dealer being a wear item Toyota are usually pretty good on price.
