Smoke out of Manifold and White/Blue Smoke out of Exhaust
MKIIISupraGuy
639
Lousy-ana
I had a emanage blue finally running on it, but the guy that was going to tune it a little better moved away, so I never got around fuel-cut. It still cuts at 10-ish, and she gets there quick, so I'm always having to feather the throttle...uggh. Currently wanting to put a Neo on her.
radiod
1,342
Abbotsford, BC
Cyrus;1853171 said:
easy ways to investigate this: for BHG do compression test. for valve stem seals, and rings, do a leak down test (NOT a compression test).
Leak down test will show more definitive results even if you have a BHG. This is by far the best option for testing to see if everything inside the cylinder is good, be it valves, rings, or gasket.
SideWinderGX
733
EMB can do everything you need. The guy that was tuning it is a complete moron if he couldn't figure out how to tune using the emanage.
