I have about 2000 miles on my stock rebuilt 7M. My motor had 95K on it and ran excellent. I'm almost sad I touched it, but I wanted to do a MHG and that involved surfacing my block, so while it was out I did new NPR pistons, rings, and all new bearings (rod and crank). I still had a nice cross hatch on the bore, so I went with stock size pistons (regrets...). I checked ring gaps upon build and all were good. I disassembled my head for cleaning and surfacing, and before re-installing valves I lapped the valves with a compound. It of course got brand new valve stem seals upon re-assembly.
The car went back together and fired up with no serious issues. I am running an HKS sport turbo with that was just rebuilt. I noticed that I am burning a lot of oil. The car billows blue smoke after decel (and ONLY after decel). Nothing on startup, nothing under accel, nothing at idle, etc. If I leave the car in gear as I slow down, I am guaranteed to get a breeze of blue smoke after I stop. If I decel on a hill, the second I get back on the throttle, I puff a cloud out the exhaust. I am running the original PCV system which includes new hoses. I did a compression test, petrified to find low compression, but my compression was fine (148 +/-2 in each cylinder). I tested the compression again and got the same results.
These signs really point to rings, but I don't see how I can have good compression? Do I have good compression rings and bad oil ring(s)? My car is finally built how I want it (Lex/560's/Walbro/AFPR/HKS sport turbo, etc), but I have this problem that I fear is in the very guts of my motor.
I'd really appreciate some tips from anyone with experience of these problems on where to go from here.
Thanks!
Thanks!
