Ok so run oem, and try to do it as soon as possible, and do valve stem seals as well. Just want to make sure, I should machine the head too in this process right?
Sent from my iPad using Tapatalk
Grandavi;1992505 said:An OEM Headgasket is totally fine (without lapping the block) provided that your head is straight and your block isn't pitted. If your running stock, its fine and should give you no trouble. Its when your trying to up your HP (adding stress) that you get issues
