***SM member 1/4 mi. times list***
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
might as well post this here so its offical lol. my best pass to date. was against a 2015 zo6. it was awesome :D
have one more try this year for my fastest pass! this is on a 255/50r16 mickey thompson et street radial too just for reference.
Archon
67
Russia
www.200mph.ru
black89t;2057614 said:
thats a fast time for that mph! whats your best 60ft with those bias ply mt's? you got some balls running those with a radial up front :aigo:
There is no 60ft checking on this event. My best 60ft was 1.94sec with ET12.43sec at another event. So I think last 60ft was better.
~12sec is not a problem on radial front, but front drag tires a better sure.
This is ET12.43sec run.
No burnout, because this way I havn't enough power for good start. [video]https://youtu.be/XrnPlzDUtvo[/video]
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
oh dam that sucks.......to run that time with that mph it had to be good prolly in the 1.7 area maybe lower!!! my buddies sti swapped legacy wagon does high 11's with like 112mph cause he launches so hard and shifts really fast. its crazy how much a good 60ft drops your time.
and the radial in front bias in rear seems to be ok if you can drive good and not make to fast of corrections even though its not recommended. ive seen videos where somebody corrects to hard and it loads one side the car to much. then the bias plys squish down too much on one side compared to the other and sends the car into the wall!
gsxr141
1,158
10
rochester
well, I finally made it to the track with my new setup.......
I only got 2 runs in before the clutch slipped. :(
ended up going 12.79 @128, and 12.76 @ 125.
needless to say, my 2.4 short time isn't helping. lol
gsxr141
1,158
10
rochester
here's my slip from 10/10/15.
mods......
built 7m with wisecos, eagles
fully built/ported head with bc 272's, 1mm over valves, ti retainers
bws366, sp quick spool valve, cast t4 manifold, 3.5" exhaust, tial wg
ffim, 90mm tb, BIG treadstone intercooler, 3" i/c piping, tial bov
fid 1000's, walbro 450, fuel lab afpr, dual fed fuel rail, flex fuel sensor,e85
ms3 pro, sti coils, 26psi
princess motorsports 1pc shaft, act clutch, chromoly flywheel, beech v2 shifter.
18x10 fronts, 265-35's,
15x8 +27 rears with 275-50 nitto 555r's.
te72
Classifieds Moderator
6,611
7
WHYoming
mods......
Dude you must be ripping those tires off on your launch, to be running that trap speed. Once you get the clutch sorted, and some practice with your 60', I could see low 11's on a good run for you. :)
As for me, my second time to the track was this past Sunday at LVMS for Supras In Vegas. Ran 3 passes in a borrowed FR-S, all within .100 and 1mph of each other. Best run was a 15.233 at 90.65, not terrible for a 102° day in the Vegas sun. I think elevation is a little over 2000' at that track. Still think it would have run a 15.1xx with another pass, I was starting to get the car figured out.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Please add me to the list!
10.202@126!
1989 Supra, 2jz, BC272, 6466, th350, Proefi.
[video=youtube;N_udPzU0FII]http://www.youtube.com/watch?v=N_udPzU0FII[/video]
te72
6,611
7
WHYoming
Chunks, there is something about the sound of your car man, I like it. Question for you though. Your ET's and 60's are all somewhat close, yet your last pass is around 10mph slower, although it was your best ET by far, across all the traps. Did you let off, or have any other idea on what caused the much lower mph?
To be clear I'm not upset, I'm just a numbers guy, and I find stuff like this interesting. :)
te72
6,611
7
WHYoming
Ahh, that would do it. If I were more handy with a welder (heh, who am I kidding, more like handy at all haha!), I would secure my intercooler pipes like the Group A cars were set up.
They had a threaded bung welded onto each end of the piping, outside of the coupler / clamp areas. Piece of metal plate with holes in it where needed, with a bolt through it, prevented piping blowing out on the driver. Quite simple, and quite ingenious, really.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Yea difficult to do when the end of the pipe uses an elbow coupler. It's one of the only ends that doesn't have a bead rolled in it. It blew out twice that day.
te72
6,611
7
WHYoming
Good idea to bead roll them if at all possible. As for working with an elbow coupler, attach the connecting strap in a way to act like the bottom of a triangle, from the side you can access. Might have to do both sides, but I think it would work.
Also, constant torque clamps work wonders for high pressure applications, it's pretty much the only type of clamp Cat sells for turbo piping...
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Well all my clamps are Turbonetics brand T-Bolt design from summit. Like these http://www.summitracing.com/parts/tnt-30275-300
They usually hold up fine, but i never had my boost up that high before. Im sure if i had rolled a bead into the end of the pipe it wouldnt have come off. But the straight flat pipe just slid right out.
Best way to do it is Van-Jen flanges but they are serious $$$$ and also require the pipes to fit up nearly perfectly. For my purposes, bead rolled pipe and silicone couplers secured with T-Bolt clamps will be fine.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
yeah you need to bead roll your intercooler pipes. i was getting boost leaks on higher boost till i did that at all joints. harbor freight has a nice bead roller that worked really good on mine. i used some angle iron bolted to the end to keep the rollers from spreading. besides doing that its pretty simple. you had to be running more than 550whp 135 trap speed is like closer to 700whp im pretty sure!
