***SM member 1/4 mi. times list***
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Here it is folks, a list of 1/4 mile times that will actually be updated.
There are 4 sections:
MKIII bodied (7m powered)
MKIII bodied (1j powered)
MKIII bodied (2j powered)
Other (ie. 7m dragster, 1uz mkiii, 7m/1j/2j mkii, etc)
Top 30 for 7m powered mkiii's (since that is the majority), and top 15 for everything else.
The list will continue on as nobody will be removed by people who get pushed down past the bottom.
Make your submission by posting the following:
  • Your time and trap speed.
  • Engine, transmission, and tire type.
  • Timeslip or video. I will work on the honor system that the timeslip is actually yours.
  • A *basic* mod list. Preferably ones that affect your time on the track - save the details of your mercury vapor interior light conversion for a different conversation, please.
Let the games begin.....
7m MKIII
  1. mibrum - 8.62 @ 158.19 - GT45, fully forged motor, GM PG trans, Mini tub
  2. besttrans - 9.43 @ 149 - T76, Accel DFI, gm auto, air/water
  3. upgradedsupra - 9.90@147 (boost only) JE's, Titanium Cunningham rods,GT4202, MoTeC, RC1000's, Custom Billet TED cams, head work, shimless buckets, Ron.R FFIM. ATI TH350trans
  4. lvfinalstage - 9.97 @ 134.11 - gt4788@18psi, aem, gm auto
  5. Slow66 - 10.55 @ 126.77 - T61, FFIM, vpc/afc, gm auto
  6. TKMK3 - 10.67 @ 132 - 72mm turbo, stock head, 5speed, n/a cams, tubular manifold, pro-efi ecu, 26x11.5 et streets
  7. csabika - 11.45 @ 131.2 - pt76@36psi, JE's/Eagle's, Cometic hg, 2 walbro's, 1000's, VEMS ECU, ET Streets, custom int. mani w/Q45 tb, air/water
  8. VanSupra -11.64 @ 120.33 - TRD Cams, forged pistons, Turbo A TB, fmic, T70 T'netics @17psi.
  9. s turbo 87 - 11.725 @ 120.61 - 60-1 CT26 @ 20psi, vpc/afc, 580s, 75 shot, BFG dr's
  10. suprakid24 - 11.77 @121.5 - GT4088R, FMIC, tial wg, AEM EMS, M/T street slicks
  11. Bigdough666 - 11.77 @114 - 60-1 CT-26, 100 shot, Lex AFM, 550s, 3" custom exhaust, "built" A340E
  12. toyman1987 - 11.81 @ 117.49 - sp63, aem, 750's, a340 w/ 3200 stall
  13. yota8791 - 11.819 @ 119.86 - greddy 20g @21 psi, 550cc injectors, Walbro, antilag, M/T ET Streets
  14. toyotanos - 11.833 @ 118.3 - Built 7M, 67mm turbo @ 17lbs, R154, BC 272's, AEM, E-85, R154, 26x10.5x15 ET Street wrinkle walls
  15. Buddafucco - 11.90 @ 123.7 - T61, HK$ WG, 22psi, 3"pipes, Walbro, AEM FPR, Greddy EMU, 4.30LSD
  16. gixxer750 - 11.90 @ 123.5 - 2.0 60', 7m, t66
  17. Suprarich - 11.95 @ 114 -1.73 60', Stock CT/IC, a340, vpc/afc, 70 shot N2O.
  18. MRSUPRA - 12.0 @ 120 - SP61GT Lex/550's/supporting mods, stock 7M w/ cometic hg, Nitto DR's
  19. drjonez - 12.111 @ 117.4 - sp57, emanage
  20. lintlars - 12.12 @ 124 - gt 35r, rebic lc, lex AFM, 680s, r154
  21. supranasty - 12.21 @ 112 - lex/550, safr, 60trim CT, stock ic, 5spd, 430s, DR's
  22. cruzian7m - 12.21 @ 112 - 12.319 @ 116.28 - 1000cc injectors, forged wiseco pistons, and pauter rods. BC264 cams, turbonetics T66, Haltech standalone, 5 speed, drag radials
  23. frontierguy25 - 12.62 @ 113.19 - Boss 58mm bolt on @19psi , pump gas, Lex afm
  24. 2543arvin - 12.67 @ 111 - 57 Trim CT, Lex AFM, Walbro/550s/afc, FMIC, DDP to 3.5"exh, 4.30's, DR's
  25. BTZ - 12.704 @ 112.58 - 57trim ct, lex/550, safcII, 5spd, stock 7m
  26. funky_monkey58 12.709 @ 125.85 - 24psi, street tires
  27. Devin LeBlanc 12.772 @ 106.46 - Stock CT26, 12psi, A340E 2500 stall, 2.5" exhaust, Sawblades with Falken zeix 225/50R 16's
  28. supraturbotimmy - 12.85@112.79 - JE's Ported head, turbonetics stage 2, Lex afm/550's
  29. silver88 - 13.07 @ 110.55 - Stock ct@14 psi, Lex/440s, ebay dp, no cat, blitz nur spec, street tires.
  30. 89turbotoy - 13.21 @ 106.6 - intake, 3" turbo back, 50 trim ct @ 14psi, 2.5" hard pipes, spearco style i/c, street tires
  31. msimsi10 - 13.23 @ 108.22 - T61 CXRacing Turbo, Wiesco Pistons, Eagle rods, 2.2 mm MHG, Studs, RFL BOV, Godspeed intercooler, HKS Dragger Exhaust and Downpipe
  32. suprra_girl - 13.37 @ 106 - 46trim ct, 3" exh, 9psi,big IC, 2.5" IC pipes
  33. kotu100 - 13.39 @ 105.78 - stock 7mgte w/ arp headstuds, 3" DDP w/ test pipe & tanabe hyper 3" catback, shimmed WG to 12psi, LEX AFM w/ 550cc inj, no tune.
  34. The Reaper - 13.4 @ 104 - 5 spd, Intake/exhaust, Lex/550's, SAFC untuned
  35. lowtaco - 13.4798 @ 104.74 - stock CT26 @ 9psi, 3in turbo back exhaust with Magnaflow muffler, K&N, FMIC with 2.25in piping and SAFC
  36. RTA Supra - 13.5 @ 104 - SC61, hardpipes, 3" turboback, street tires
  37. Sawbladz - 13.62 @ 102.25 - 12 lbs on stock CT, Full exhaust, hardpipes and coilovers.
  38. Boost Lee - 13.76 @ 105 - Stock 7M-GTE, ct26 @ 10psi, 3" Exh, int. w/K&N, auto, Street tires.
  39. WeDgE - 13.82 @ 106 - Blown T78@13psi, Lex/550s, 3" exh,FMIC, 4.30s, DRs, E-manage
  40. kckazdude - 13.93 @ 97.36 - Stock CT-26, 2.5" IC hardpipes, Spearco replica IC, knock-off DDP, full 3" exhaust no cat, modded A340E, Aluminum DS and open 4.3 differential
  41. tsupranami - 13.95 @ 103.6 - upgraded 46 trim CT26, Apexi SAFC and AVC-R, 245.40/18 (r) and 235/40/18 (f) street tires, RPS clutch with full face OEM disk
1j MKIII
  1. Twin 1jz - 9.48 @ 146 - twin k26's, slicks, and open exhaust
  2. suprahero - 11.619 @ 125.08 - R154, 6765, 23psi, Mickey Thompson ET streets
  3. MattOneDizzle - 11.67 @ 127 - 5 Sp, 61mm
  4. becauseican - 12.01 @ 118 - T61, 22psi, 750cc injectors, water meth, MT ET street radials, 5 speed
  5. suprahero - 12.08 @ 118.67 - 5sp, GT35r, 540's, Walbro, Ported head, Crower 272's, FMIC
  6. jz*supra - 12.37 @ 116.05 - MP T-61, crower 272's, 680CC injectors, Lightweight flywheel & ds, Nitto 555Rs, HKS v-pro base map only, 18 PSI on pump
  7. 1JZ A70 - 12.459 @ 111.11 - intake, exhaust, IC, power FC, 18psi, 98ron, m/t et street drag radials, stock twins
  8. SupraRacer - 12.6 @ 112.8 - stock twins
  9. claytonio disastro - 12.90 @ 108 - 1.8 60ft, stock twins, full exhaust, stock boost/ecu, bfg dr's
  10. ForcedInduction - 12.96 @ 113.30 - 61mm w/ supp. mods, street tires, pump gas.
  11. Mofo - 13.05 @ 110.02 - stock twins, custom int and exh, powerfc, ARC IC.
  12. 921JZ-GTE - 13.08 @ 105.88 - stock twins @ 14 psi, ceramic clutch, 1 pc. DS, street tires
  13. tissimo - 13.42 @ 112 - 2.2 60', t67, 17 psi, crower 264, aem
  14. BlackMKIII - 13.46 @ 109.7 - stock twins @ 1.3 bar, 3" exhaust, RFL BOV, 2.5" piping w/ fmic, custom CAI, Walbro,AFPR,AFC, 4:30 LSD
  15. DLM - 13.46 @ 101.45 - stock 1jz auto, stock i/c & pipes, 3" dp & exh, K&N
  16. te72 - 13.577 @ 103.89 - stock 1j bottom end, ported/polished head, BC264 cams, 3" exhaust from turbos back, stock twins @12psi
  17. annoyingrob - 13.606 @ 103.21 - Stock twins, 15psi,Divorced y-pipe, intake, exhaust, Crower 272s, V-Pro
  18. The Reaper - 13.72 @ 102.82 - 5 sp, intake, exhaust, stock twins, 11psi
  19. onejz - 13.74 @ 99 - stock twins, DP, exhaust, K&N filter
2j MKIII
  1. big daddy - 8.7 @ 165 - 3.0, AEM, Bullseye s480, PG
  2. 2jzmk3 - 10.3 @ 147 - 3.0, 78mm @ 22psi, motec, 6spd, 26" mt radials.
  3. 2JZ_MA70 - 11.544 @ 131.51 - M/T Drag Radials, w/o 2 step. Full weight supra, 5-speed
  4. SD2JZA70 - 11.6 @ 122 - stock jdm 2j, GT76, Haltech e11, 1000cc, custom int. mani, 4" exh, twin disc, BFG dr's
  5. Grimjack - 11.63 @ 123 - 5 speed, slicks, dbb 67mm turbo, 890cc injectors, water meth, Vipec v88
  6. suprahero - 12.08 @ 118.67 - ported 1j head, 5sp, GT35r, 540's, Walbro, Crower 272's, FMIC
  7. leecheater - 12.36 @ 119.27 - GT3582r @22psi, 1200cc, AEM ECU, 24x12x4 ic, Aeromotive FPR/pump, 1pc jawsgear Steel Ds
  8. Kyle Hunter - 12.37 @ 113.93 - SPSS700GTBB Turbo, AEM EMS, V160, Lipp traction arms, Eibach/Tokico HPs, 275/40-17 Nitto 555r, race weight 3840 lbs.
  9. Dew511 -12.4x @ 125.xx - 1j head, T61, 550s, Crower 272/272, Wolf ECU, R-154, Street tires
  10. NewGen - 12.41@109mph, 1.7 60ft. @JZ, T70 turbo
  11. tissimo - 12.647 @ 113.56 - 2.09 60', 2jz, stock twins, 16 psi , aem, street tires
  12. dok33 - 13.17 @ 120 - T70, Lex/SAFC, 880cc injectors
OTHER
  1. mibrum - 6.98 @ 193 - 1.05 60' - 7m powered rail dragster, GT4788 turbo, tec3r, SIP pistons, SIP crank, 5 speed gerico, water to air charge cooler, ect, ect...
  2. darkspeed - 11.02 @ 129.xx - Mkii, 6MGE-T, Megasquirt ,SPEC stg3+ (W58), LSD, ET drags, t61
  3. Clifton - 11.67 @ 135.38 - '73 240Z, 7M, MHG, K&N, 4 puck, big turbo, injectors, exhaust, FMIC, standalone.
  4. ARZ - 11.75 @ 124.8 - '71 240Z, 7M, 5 sp, stock clutch, h20/meth, t4/60-1, 22~23 psi,
  5. speedfreak426 - 12.49 @ 117.56 - '77 Celica, 7M, R154, 14psi, FMIC w/ 2.5" hardpipes, 8.75" Mopar rear
  6. kmfdmk - 12.88 @ 112.82 - 85 supra, 7m
Dew511
Q-boro, NY
Slow66- I guess it would be better for you to update the list
Under MKIII 1.5J... i guess somewhere
Dew511 12.4x@125.xx - T61, MKIV 550s, Crower 272 in. ex., Wolf ECU, R-154, STREET tires!
Time slip is at home
tissimo
Stock is boring :(
Melbourne, FL
ooo.. fun.. I'll get slips of my 2j car tonight
my old 1jz 13.42 @ 112 2.2 60' lol
1jz, t67, 17 psi, crower 264, aem, sliping clutch, bog 2nd
http://videos.streetfire.net/video/6dd53740-6733-4f04-9669-987300028a0e.htm
I ran my 2j car last week as well.. 13.1@110 2.2 60'
2jz, stock twins, 14 psi peak, aem, street tires
will get slip when I get home, friday will get better times on more boost..
Edit: since doing 40 7ms, this might be on for a LITTLE bit till people actually post up their time..
14.33@95 mph 2.0 60'
7m, Stock intake/exhuast, 10 psi falling to 7 psi
edit again: wow that was 3 years ago in a couple days.. hahaha
tissimo
Stock is boring :(
Melbourne, FL
Slow66 said:
Lets see if you can get somethign to get on that "others" list too tissimo ;) :D
I'm using a 7m intercooler on a daytona, will that count? ;)
I do have a 7m in my garage waiting to go into a truck or mkii..
suprarich
Guest
Nov 9, 2005
2,187
ohio
What is everyone waiting for? Supraforums to update their 1/4 mile time list??
Come on, more people on this site need to post up their timeslips. How are you going to let a stock ct with a stock intercooler be # 5 on the list???????
Slow66
Apr 3, 2005
1,457
Newington, CT
I know a few for sure are faster than me....Tony (lvfinalstage), and Shawn(besttrans) and a few others from the Jersey area too. Also Mibrums dragster and arz and the other Datsun/7m guys for the "others"....but i dont know their exact times (and most of their mods).....i was hoping they'd see this and post.
Maybe i'll just search thru all their stuff and just find the best times i see and post them until they see this.....
MRSUPRA
838
Maryland
12.4 at 119mph.........SP61GT@24psi Lex/550's with supporting mods. Stock 7M with cometic headgasket. Nitto DR's
12.4 at 116mph..........HPF turbo kit with SP59GT@20psi Same supporting mods. BFG DR's
Sorry, no timeslips..And no reason to lie.
suprarich
Guest
Nov 9, 2005
2,187
ohio
I have Gary's times in my e-mail and some video of his passes. He is doing amazing things with that dragster. I just e-mailed him about it. His times are down into the middle 7's. I have his mod list too, but I won't post that to protect his set up.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
14.29 7m powered, Intake and open exhaust. Also had my friends sticky 235's at back, not DR's, but very good tires.
Slow66 edit: need a mph :) Timeslip would be nice too.....not that i dont have any reason to believe you....
ninja thomas edit: i will try to find that timeslip, but i remember getting a 155 km/h, which is roughly 95 and a half mph?
2nd edit. don't put me on the list, i just read through it all and it makes me feel disappointed :rofl:
tissimo
Stock is boring :(
Melbourne, FL
ok update on my time on my 2j car
12.647 @ 113.56 2.093 60' 16-18 psi
mph is weak, need more tuning! I'll get the slip up tomorrow
tissimo
Stock is boring :(
Melbourne, FL
yea :( I'll have an update time tomorrow.. plus my buddy is going to run his 1j car as well.. maybe I should put my radials on and take #1... I think I might be able to on street tires (need to get 1.9 60s).. we'll see :)
