Yep Vanes are the critical component for cooling, DBA Vanes are omnidirectional so the slots face backwards.BrandonW;1854544 said:i used blanks for the rear
the way they came it said one was a passenger side and the other a drivers side and they had different par numbers and even had a diagram to show how to install them correctly, possible that's wrong but
"For rotors with slots machined in the opposite direction as the internal cooling vanes, the slots should lean toward the front of the car."
IJ.;1854224 said:Only ever used Yellows so NFI on Reds/Greens sorry.
Thanks for that, used "R" pads in the past and had a few "Ohhh SHIT" moments when stone cold so shyed away from them this time and used the Yellows.xPUNKx;1854604 said:I'm currently running the redstuff pads with RDA slotted rotors. All I can say is they are a lot better than OEM pads, and like most track pads the hotter they get the better they perform. Haven't tracked my car yet so can't tell you what fade is like. For street driving they have good initial bite, you don't have that OH SHIT moment when the brakes don't work like some other cars I've been in![]()
No kidding, now the manufacturers yell at you to make sure you're getting the right pads for your applicationIJ.;1854728 said:Thanks for that, used "R" pads in the past and had a few "Ohhh SHIT" moments when stone cold so shyed away from them this time and used the Yellows.
T701jz;1854513 said:This is the second time I've seen members installed those slotted or drilled rotors backward.
Vanes direction vs slots directionsupradjza80;1855006 said:I think you are mis-informed. You cannot tell the correct side for a directional rotor by looking at the Slots on the rotor. It is all based on the internal vein direction which you cannot even see in this picture...
T701jz;1855029 said:Vanes direction vs slots direction
In this case I wasn't talking about the vanes direction (cooling). I was referring to the slots direction. Manufactured would say it does not matter... lol. I did some test to see if it really does not matter (wrong). Using the direction of the mfg caused damage to the disk a lot sooner and the vibration (noise) was a huge factor. Opposite direction did perform a lot better with long life span of the disk/pads, less dust build up, and quieter performance. Mind you the vanes were not directional so it did not matter. I and the mfg have a different perspective/theory when it comes with inclined cut... meaning which end of the slots touches the pad first.
Funny thing about these new slotted/drilled rotors (straight vanes) I bought it had a marked (D-rotor and P-rotor) @ the direction just as how I would install it...lol
