IBoughtASupra;1689519 said:
I always adjust the pedal to have an inch of play wheather using a stock or aftermarket clutch.
That's where my buddy's is. About 1-2 inches of "free-play" until it starts engaging.
airhead04;1689524 said:
Kenny,
I have an ACT clutch set up as well, and mine has began to slip as well, and Ive only been driving on mine for 9 months.
I broke mine properly as well. At least to the best of my knowledge. So this may be a new thing that has developed from ACT. Just food for thought.
-David
Bummer man...
IwantMKIII;1689550 said:
Hope this is not a trend. That clutch disk in the pic looks awful, but if they say its normal....
I just switched from RPS 3200 6puck combo to an ACT extreme 6 Puck setup. No complaints at all. Much smoother engaging than the RPS ever was. Again i hope this is not a trend, though I am using a 6-puck vs. your disk setup which could be the difference.
PS - clutch pedal always should be adjusted after a new one is installed. It can preload the clutch causing it to not fully engage. Personally for both clutches I never had to adjust it, I just know it should be checked. Its very awkward to get to, if you're a big person, consider removing the front seat.
Edit: is its possible your PP bolts were not fully tightened or maybe backed out causing uneven pressure?
Yep, he said that the clutch looks normal and has no evidence of slippage; but, in the same breath he said that it looks like it is slipping due to an improperly adjusted clutch pedal...? I'm guessing that's the standard "Dodge the Bullet" approach.
Only two PP bolts were looser than the rest. Loctite next time!
The clutch pedal adjustment makes sense to me. Maybe that's the root cause.
What I'm going to do now is compare thickness measurements between the Fidanza and the Stock Flywheel. If there's a noticeable difference between the two, then to me, that would confirm the clutch pedal theory and I'll get a new disk and try again. If the measurements are fairly close, I'll rethink all of this and maybe do something different.
In the meantime...the additional requested pics will be emailed to Ryan in the morning...
