Single Turbo Questions...
rakkasan
Currahee!!
Fort Campbell, KY
I run a 60-1 (62mm wheel) that Jon put together for me. .58 V-flange rear housing, makes full boost around 3700rpm. I maxed out at 527rwhp with it. I love it, awesome set up.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
OneJSupra;952445 said:
This is a garrett 60-1 turbo I am looking to buy. Any feedback on this. Please turbo expert chime in.
COMPRESSOR SPECS:T04S housing ,flow: 61 lbs/min 781cfm, .70 A/R housing, 60 TRIM wheel.
TURBINE SPECS:T3, .63 A/R housing, HIGH FLOW 76 TRIM stg 3 wheel, oil lubricated centersection. comes standard with 360 degree thrust bearing, supportable of 575whp!
edit: That girl again...damn !
One thing to keep in mind here, .68 T3 != .68 T4. A .68 T3 is going to be RESTRICTIVE. If you're looking at a T3 flange, look at a .8x.
