tturnpaw;1238343 said:
You might want to do some research. I'd be impressed to see a tiny turbo alone on a 3rz hold 30 psi even if it fell off on the top end. Anyone else want to add anything?
tturnpaw;1238171 said:
Again the charge pipe between the two was backwords. It may be fine for a diesel but the major reason for having a setup like that is to aid in spoiling the larger turbo. It's not complicated if you understand how they work. There is no trying to keep the boost down when you have a wastegate. There isn't one on that setup again because diesels are different. They can be tuned to 60-80 psi easily. Gasoline is a more unstable fuel with a much lower combustion temperature and diesels run off of compression not spark. You cannot compress compressed air! In other words running 5psi from one turbo into another does not recompress the air it just forces the second turbo to spool faster. It's about volume not pressure.
I really don't know where you do your research... There's a big difference between flow (volume/time) and pressure (force/area). A BIG difference. The pressures produced by turbines on a diesel application are much higher due to the nature of a diesel engine. It's not apples to apples... but the same rules apply for turbocharging.
Regardless, there's an interesting phenomenon with compressors where they compress air. For instance, when you have a single turbo putting ~14psi, it's (on average) packing twice as much air into the same volume as ambient (atmospheric) air. Now, were that compressor inlet air to be already at 14psi, and coming into the turbine set to compress the same ratio, it would double the pressure again. A turbine's limits are essentially at what muiltiple it can step up the pressure, because to do so it must spin faster, creating more heat and stress in the turbine itself.
You cannot compress compressed air? How did you arrive at that scientific conclusion? How is stepping up the pressure from ambient, to 20psi, then to 40psi, then to 80psi, via 3 compressor stages, any different from having one compressor capable of 80psi? Have you ever seen a 5000psi compressor? There's no difference between the compressor on my garage floor, a supercharger in a top fuel dragster, and a turbo in your car... they all do the same thing from a physics point of view, only they are designed for different purposes by different means. Yet, the laws of physics are not independant for each application.
Tubrocharging for horsepower is not about volume or pressure, it is about flow... or volume per time... CFM (Cubic Feet Per Minute). The amount of air flowed per unit time. For example, if your turbo could have 1000000000 cubic feet capability (volume) and my turbo could flow 600CFM, I would tend to think my car will go faster than yours... yours will probably not even start. Infact, I don't think one could really quantify a turbo with only volume. Maybe a compressor tank, yes, but not a turbo.
Pressure in the concept of turbocharging ICE engines, is essentially the pressure created by the difference between the volume of air compressed by the turbo per minute and the volume of air actually used by the engine in that minute. Imagine drinking water from a pressurized hose... if you don't drink fast enough, you'll wear most of it.
I question if you know anything about turbocharging theory. Perhaps you should go do more research.
