SIEZED ENGINE
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Wow, thanks guys. I did not know there were so many options ....
Now if I am able to free up the engine, which I think is most likly, I know I should not crank it and let it run. I will turn the engine by hand a few revolutions for sure.
I will let the anti sieze ( whatever fluid I decide to use) drain completey. Most probaly overnight.
Should I fill it up with oil and drain it and then refill before starting? Or just refilling it with oil and starting it normally be fine.
What should I expect to screw up in this process?
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
some thing i lesarned recently about getting rused or broke bolts out is hesating, and then while hot drip candle wax on the broken bolt and let settle, then re-heat and apply more wax, sit again, then try to remove the bolt. the perifine does some thing and free's up bolts..
/rant.
