Yeah, time to take care of that with an update!
1. Install Eibach lowering springs (before and after pics to come!) CHECK!
2. New brake pads all around -CHECK!
3. Adjust E-brake (doesn't work at all) - Problems, and I'm out of patience. A friend with a car shop is looking into the loud noise coming from rear passenger wheel.
4. Install SAFC II - CHECK!
5. Install Blitz turbo timer - CHECK! (just need to take care of e brake)
6. Install stock intercooler that I just flushed, straightened and painted CHECK!
7. Raise exhaust (cause she's bottoming out a lot these days) - CHECK!
8. Take a serious look at timing - possible cause of sad dyno numbers - CHECK!
9. Install new radio antenna CHECK!
10. Hardwire in a triple accessory outlet CHECK! - Nevermind...
So it's all pretty much done, and she looks soooooo much better on the new springs! I have to get some pictures posted.
I've said before that I SUCK at wiring and just proved myself right. I managed to screw up while hardwiring in my 3 plug outlet and burned the freaking thing up - smoke pouring out as soon as I put a plug in it.
I took a look at my timing and found that it was only advanced to 5 or 6*. Weird, because I know it was higher before, so I went ahead and advanced it to 10* for now.
The other thing is that my ebrake is a mess. Somebody had put the rear calipers on the wrong position and so there was no access to the adjusters. I didn't feel like pulling the calipers and thought I would see how far I could get with the lever adjustment. It adjusted to about 7 clicks and holds the car on a hill, but now I have a really bad clicking from the rear passenger wheel. It's definitely the e brake, but I am out of patience and time since we are heading for Chicago on Friday for a long weekend. I'm dropping the car off at our old mechanic's shop tomorrow to let him mess with it and convert my air over to R134. With all that going on, it might be next week before I get pictures posted up, but WOW what a difference!
Oh yeah, that reminds me; I brought the car in for an alignment and they weren't able to get everything in spec. Mostly problems in the front because some dork (probably the last dork from a year ago) rounded off several of the bolts/nuts/whatever. Not happy about that. :nono:
