rtrdpenguin;1216299 said:
Wow, so many lights!
What's that thing next to the apexi unit (which looks like CF?!) with the turbo and oil icons?
It is made from plastic (heat durable) custom made.
The oil thing is the oil level light warning.I have a 2jz under the hood and
it supports this kind of data reading.
The light stays always on.....when it will go off then the oil level in the oil pan will be low which means problem! :sarcasm: I could have made it vissa/versa (to light on when I'll be low on oil level) but I needed to get
a special relay. Now when I turn the car hard on corners I can see the oil
level light going off for a second :biglaugh:
The turbo light is a show of light that indicates 2 and 4 digit numbers....
It is a designation for the sequential twin turbo setup. 1st turbo spools
at about 2k rpm and 2nd turbo kicks in at 4k rpm.....:biglaugh::biglaugh:
The power source light came from the old ashtray light :sarcasm:
Creativity at it's best :love:
