u should not be coming in here trying to talk trash about our front mount and how dumb we r for having it on the car i mod my car for my self and not for you so what dose it matter if u got nothing nice to say then keep it to yourself
QWIKSTRIKE said:I see some pretty large Intercoolers and some pretty small turbos, you guys havent got a clue to what size IC is needed for a given turbo. Personally you will not need bigger than a 12x24x3 for 98% of the guys in this forum. The larger the IC the higher the lag or spool time. Even with my GT4088 turbo I could see a slight difference in spool for my 12x24x4 from my original IC of 12x24x3. Wake up BIG IC's DON'T make power! If the turbo can not pressurize it properly you will lose power. For the guy with the IC hangingto the fron lip...you reallly are clueless and didn't research what size IC you reallly need; not to mention that going in and out of driveways that are raised will cause it to hit the ground. Hello IJ whats popping dude!
Satan said:Getting ready to put my 24x12x4 back on, now that I got my RR-FFIM. What did you guys do about the oil-cooler, when putting them big@$$ ICs in there?
