Should I???
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
HellsLegion said:
R you serious???
Dont tell me that!!!
Do you really think so??? There are no funny sounds coming from the engine, and there are tones of wireing and hoses loose or disconected!!!
Some one send me a nice stock picture of the 7mgte, so i can connect the lines....
Thanks guy's:1zhelp:!
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
You car will normally overheat.
When the headgasket blows. The small area between the cooling jackets in the engine blok and the piston crack(gasket does) which in turn leaks coolant into your oil, which also in turn burns cooland which makes your exhaust white.
And will also mix with coolant, so check the oil cap.
