Should I jump on this? 91 targa turbo, about 80k original miles
te72
Classifieds Moderator
6,619
9
WHYoming
Doat
2,599
Houston, TX
I have a question, the targa support brackets in the trunk fall when I put the roof on them, the brackets in the very rear that lift up, these
How can I stop them from just giving way and actually support the roof or do I have to get new ones?
Doat
2,599
Houston, TX
Finally drove the car home today and ran beautifully, the temp gauge did fluctuate a bit but I am pretty sure it's just from air pockets in the cooling system since when I changed the radiator we filled it up and drove it around. So when it cools down a bit I'll check it out and try to remove the air from the system. Here are a couple of pics I snapped real quick
Not sure if I will make a thread just yet since I don't have any immediate plans other than a little touch up work.
Doat
2,599
Houston, TX
Hahaha I can't do that man I love the way it looks but I do need to replace the rear targa supports in the trunk, the ones right by the taillights and a driver side window switch.
I checked my radiator and it seems to be dumping coolant into the overflow tank because that is almost full now and the radiator is low, why does it fill up the overflow tank?
