Should I get a flywheel
supra8903
512
Latham, NY
Im in need for a clutch and Im wondering if I should get a new flywheel, or should I just het mine resurfaced. Any coment or good flywheels please let me know.
How much do they really do. I have already removed my fan from the h2o pump.
Joe
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
stock flywheels are pretty heavy....
if u get a lighter one if frees up about 15 hp.... and faster revving....
what do u mean how much do they really do ??? hp u mean??
Yes
A flywheel stores energy.
It may take more load to get it turning if it's heavier so slower acceleration but it doesn't actually "give hp" if you lighten it.
If you go too light in a fat pig Mk3 you can hurt drivability down low.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I picked up one - mostly because I didn't want to pull the existing one and wait to have it machined, I wanted a 6 hour swap, and me driving the car again without any downtime.
I haven't been sorry yet, picked up the RPS billet flywheel.
T34418L3ONE
Supra for brains.....
Jul 3, 2005
225
Pleasanton
it doesnt add horsepower, it just lowers the amount lost through the drivetrain. Same with the aluminum driveshaft, the less weight the motor has to turn the more power is available to the wheels.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I was just thinking maybe to get the best of both worlds a company could make a super lightweight wheel, probably out of chromoly that would be the skeleton for the friction plates and ring gears only. That wheel would weight probably around 4-6 pounds, so your car would easily fly from the start, and then as the flywheel turned quicker it could act like some sort of electric generator and create a magnetic field to draw rings of metal onto the disk surface to add weight as you went faster, to keep a smooth acceleration, and so as you decelerated the rings would be pulled off the wheel again and the flywheel would be light and easy to rev.
Maybe I'm just nuts today also :icon_razz
eric
Dec 3, 2003
6,653
Canada
Joe
I run an OEM flywheel and is what I would suggest in doing. Best bang for the buck. You can get yours resurfaced or give Champion Toyota a call. They have good prices.
I run decent hp and have no problems
Duane
Dec 3, 2003
6,653
Canada
Billet what? Billet wood? billet steel? billet Aluminum? LOL :naughty:
Duane
figgie
Twin Cities, Minnesot-ah
huh?
it does not lower HP. Heavier means more inertia to overcome. the same hp still flows through it 400hp = 400hp. The HP loss actually occurs in the transmission and differential.
