If the spring compressors don't have the locking pins (you'll know what I mean when you see them) I wouldn't touch them.
Poodles;1362391 said:If the spring compressors don't have the locking pins (you'll know what I mean when you see them) I wouldn't touch them.
figgie;1362172 said:..And the quickest way to do the 1/4 is to toss your car off a cliff that is higher than 1320 ft.
The thing with cutting springs.
Do anyone here know how much to cut to not increase the rate of the spring by to much? Oh wait, you didn't know that cutting the spring affected the linear rate of the spring?
Do it right or don't do it.
Supracentral;1362584 said:nose, while I can agree with you in principle, most people who cut springs aren't going to do do it correctly.
Springs are cheap. Dirt cheap. It's dampers and coilovers that cost money.
Most of the time when you see someone who wants to cut springs, it's because they are broke. They'll want to reuse the busted ass old stock shocks and will invariably cut too much off the spring.
Can it be done correctly? Yes.
Will it be? 99 times out of 100 - No.
Supraholics;1362151 said:I heated the front ones on my white Supra only because I had a meet to go and the front INTRAX spring were still almost at stock height while the rear were perfectly lower.
I was told they have to seat for a while and eventually they'll go down to where they should be.
I wouldn't recommend people doing this. Springs are just too cheap NOT to buy a lowering kit.
I will though share my personal experience. The ride was just as good as the intrax if not stiffer. No harsh ride or bouncing. Cornering up to and around 60mph (I didn't do hard cornering past that speed other than HWY driving) was very good as well. One problem is that by heating the springs, you're making them smaller and when the suspension is fully stretched the springs will come loose and move around which is very dangerous.
Pictured below with heated springs. (only front was heated - rear were Intrax)
nosechunks;1362806 said:agreed.
