mattsmall said:
the stock exhaust valves didnt have a problem at .008 and its a lose .008 not a tight .008 by the looks of the stock cams it doesnt look like the back of the lobe ever touched the shims.
its raining right now but ill take a look at everything tomorrow how do you adjust the timing? and should it be at 5* or 10* when at idle?
You measure when the engine is cold, but when things get hot they expand, that's what's the clearance for. The expansion could be bigger than your clearance if it's too tight and then the valves don't close properly anymore and you will be losing power. That's why it's best not to go below factory specs, so 0.010in would be lowest.
Furthermore, you say it looks like the back of the lobes don't touch the shims. Might want to check if your springloads are still within spec.
And you can't adjust timing on a jz engine, it's all ecu controlled. The only way would be using a piggyback.
