At stock timing it sounds like there is a bad exhaust leak but when I advance the timing it goes away
set timing correct....
motor tdc (verified by ratchet extension down spark plug hole lol)
crank pully lined up at 0
cams lined up perfect
insert cps properly (done it 1,000 times)
diagnostic box jumpered
car warmed up
start it up, car sounds great pulling -20 vacuum, idles good
check the timing its advanced to over 20 degrees
WTF stock is 10 degrees
adjust the cps down to 10 degrees and it sounds shitty, and like a bad exhaust leak, vacuum -15
idle is good though at stock 650-750 rpms
verified with 2 timing guns
car warmed up
