Well I picked up my 91 turbo 5spd mk3 yesterday and I have noticed that my reservoir tank gets full of coolant after long drives, now I don't drive the car often because I have another car that I use as a daily. Question is which route should I take? Re-torque the stock bolts until I can replace the gasket, use head gasket sealer until I can replace the gasket, or just let the car sit for awhile until I can replace the gasket?
I've heard mixed things on re-torquing the stock bolts to spec or a little more than spec and mixed things on using head gasket sealer for the meantime.
One more thing, sometimes when I shift into reverse I hear a pretty loud metal clank then when I shift back into reverse it sounds normal, what could this be? It doesn't happen often it's more random.
