Seafoamed the Supra
iwannadie
981
gilbert, az
its funny, on a motorcycle forum i go to they seem to love seafoam. i never tried it, just seems like another snake oil to me.
on that forum theres 2 additives you hear recomended. seafoam and techron fuel add.
ive ran techron through the supra and seemed to help a bit. but who knows, could be all in my mind lol.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
As I said, the product has it's uses. It's popular with bikers for a reason. I also ride and used Seafoam in the fuel for years. The naphtha in it works well to clean fuel varnish in my Vulcan's carbs but after a bit of study and testing I found something that does a better job. Since you brought up Techron and I brought up PEA here ya go. It's the same stuff:
PEA is Polyether Amine. It's the active chemical in Techron and a few other aftermarket fuel cleaners. Chevron's Oronite Division is the inventor and world's largest supplier:
http://tinyurl.com/c25dqzj
PEA is used in varying amounts in almost every quality gasoline made. The problem is unless you use one from the day an engine is new or rebuilt it takes time to clean things up. That and the amount varies from one fuel brand to another. The way to overcome this is to use a PEA based cleaner a few times a year or with every oil change and a good quality fuel (www.toptiergas.com) in between.
Typical fuel cleaners are solvent based and therefore cheap. They don't do much other than make your idle nice and that isn't from any cleaning action. PEA cleaners cost more because PEA is expensive to produce compared to solvents but also far more effective. The leading PEA based cleaners are GumOut Regane (yellow stuff in clear bottle), Redline SI-1, and Techron Concentrate. Each of these products has any where from appx 30-50% PEA with RedLine SI-1 having a slight edge. The cheaper Techron ProGuard also contains PEA but at a lower concentration. Not a good value.
Gumout Large Vehicle Fuel System Cleaner in the gold bottle is also PEA based. It contains the same percentage of PEA as does Regane but in a different carrier. It's 20 oz size makes for a better value if you can find it. Be sure it says "fuel system cleaner" and not "fuel injector cleaner". The bottles look nearly identical but the fuel injector cleaner contains no PEA.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
Thank you JJ... some very interesting information there.. I think I'm going to look into the Redline SI-1 or the GumOut Regane and try it in both of my cars...
Doward
4,245
Alachua, FL
Yes, you can get Redline SI-1 from Autozone for $8/bottle. I use it every oil change, into the tank when I hit 1/4 of a tank left.
gixxer750
2jzget comingsoon!
Mississippi
Speaking of Redline Fuel Cleaner....not to thread jack...
Tomorrow, walk into your local advance auto parts(price changes go through in the morning), walk to the chem wall, and pick up redline fuel system cleaner. Walk to counter with it and check it out for half price. It is discontinued as of tomorrow @ 9 am when the stores open. I think price is 3.95... If you are good, you may be able to talk them down on that a dollar or two.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
[strike]Looks like it's already happened. Now if we can get a mod to delete that and the other posts he's made...[/strike] - Mess cleaned up. -SC
Since I'm here I'll say, as far as I know, not much has changed since 2006. Techron and Redline SI-1 are still the most commonly available sources of PEA and are what you should be using. Solvent cleaners are a waste of time and money. My program was one dose of PEA cleaner with each oil change and an on-the-car (through the rail) cleaning every two years. If you don't want to do that at minimum use a Top Tier fuel.
