Chaingun;1759803 said:This was mated to an R154 Lime?
"Solstice" uses a 154ish trans so I'd say yes.
IJ.;1759813 said:"Solstice" uses a 154ish trans so I'd say yes.
limequat;1759947 said:R151, same thing with a t/c.
You wanna sell a few copies of that bash guard?
Chaingun;1760037 said:What would you be willing to let the cnc files go for? I can have them done at the Votec in my area
IJ.;1759813 said:
Hard to say with you being LHD but I "think" a set of huggers might work okChaingun;1760263 said:I certainly understand, i'll probably have to draw it up in CAD and have one made. Once the motor is in my next hurdle will of course be the exhaust. IJ as always you are the resident expert, Would you think that an SBC or LS1 sitting in about the same position yours did could run a set of block huggers such as? If so it will make routing the exhaust a lot easier and converting from the SBC to LS1 exhaust when the time comes as easy as swapping the headers and welding in the bungs for the o2 sensors.
Combination subframe brace and bash guard Brad, the LS F Body pan hangs down about 3/4" and being Cast aluminium don't dent they crack so I wasn't taking any chances.te72;1760340 said:I think I may be looking at this the wrong way, but is that your version of the under-tray, or is that more of a skid-plate to protect the oil pan? Either way, looks nice.![]()
hhsuperwhite90;1764412 said:Try the TRD disc for an FJ Cruiser, it's bigger than the one from Advance Adapters. I have the one from Advance Adapters and it is 10.25 inches in diameter, but listed as 10.5 inches. I set this up on the LS6 clutch pressure plate I have and there is about 3/8" that will be unswept on the disc itself. The TRD disc is meant for the supercharged FJ and is rated @ 340 HP 10-7/8" diameter, it will still have the same amount of disc unswept but with the larger diameter it will make up the 3/8" for max contact. The TRD disc (part #TOYOTA-6011895-FJ-TRDSP-4) cost me $120 shipped.
www.dealerdirectparts.com/ProductDetails.asp?ProductCode=TOYOTA-6011895-FJ-TRDSP-4
My set -up consists of:
Genuine LS6 clutch kit new off ebay $250, about $500 new from many suppliers.
Novak adapter $300
Keisler LS bell housing $250
Solstice slave $75
ARP pressure plate & flywheel bolts $50
Jags that run (4PAC-TOY)vss sensor gives ECU the speed signal and still lets me use the stock cable to the speedo $100 http://www.jagsthatrun.com/Pages/SpeedSensors_Speedometer.html
still researching the pilot bearing & hydraulic line
Chaingun;1764545 said:I wasn't really thinking about the master to be honest but now that we're on that I'm wondering if the master for the R154 will have enough pressure to move the slave cylinder on the new setup,
