sbc in a MK3...
lowtaco
282
Under a damn Toyota
Suprapowaz!(2);1822298 said:
Which heads do you plan on going with? How did you make your motor mounts? Nevermind, I forgot it's posted on the first page.
I am still saving for the AFR 195's but have a nice set of ported 487's now with 2.05/1.60 valves will roller springs to get me started
Suprapowaz!(2);1822643 said:
Probably "bad mother fucking small block chevy for the mother fucking win."
Winner!
Oh and the mounts I made work great but do to header clearance issues I need to do a re think on them.
lowtaco
282
Under a damn Toyota
Wiring owns me... I know this is just a easy sbc swap but I decided to get rid of all the extra wiring that isnt needed. So I have stripped the car of all the wiring and de-pinning all the un needed circuits. I had so many that were hot with ign on I didnt want to just cover them over and chance burning the car down.
So far everything still works lol, Im glad I have the factory wiring diagrams to help.
lowtaco
282
Under a damn Toyota
Getting back to the dead thread... Sold the ported 487's, bought a set of Darts SHP 200cc heads with 72cc chambers. Finished the engine off with Harland Sharp rockers, Comp pushrods, Dart SHP intake and made a new set of solid mounts.
lowtaco
282
Under a damn Toyota
Better view of the new mounts... The legs attach to the factory crossmember with 1/2" bolts. A person could easily make the legs 1/2" shorter and use a flat rubber mount bushing (V8 Landrover) and not have to worry about being solid mounted. I still plan to run a poly trans mount just in case.
552141_487798657898648_1136773848_n.jpg 314216_492506850761162_1069807834_n.jpg 206030_493473953997785_1690381809_n.jpg 284693_493473830664464_1740222862_n.jpg
539160_493473250664522_1244705544_n.jpg 376652_493472970664550_1850331056_n.jpg
te72
Classifieds Moderator
6,611
7
WHYoming
Poodles;1872235 said:
SBC + solid mounts = I'll NEVER ride in a car like that again
Curious what that feels like... I imagine something like riding a hardtail Harley on a bumpy road?
The guy didn't run them for long. He got tired of screws and interior trim falling off...
You couldn't see out of the mirrors :rofl:
te72
6,611
7
WHYoming
So, about as smooth and balanced as a sober man on a cruise ship? :p
lowtaco
282
Under a damn Toyota
I wanted to use the factory rubber mounts but figured they would rip apart eventually. Solid mounts have been used for years in race cars, I should have just used an engine plate instead.
te72
6,611
7
WHYoming
Could always just say that all the shaking is all that Chevy power, if anyone happens to ask... if it doesn't bother you, then why worry about it? It's a MAN car, not some sissified comfy commuter-mobile, right? DAMN STRAIGHT, who's with me? :D
lowtaco
282
Under a damn Toyota
Poodles;1875119 said:
SBC's are inherently unbalanced...
And JZ engines are like LSx engines. Over-rated.
In other news I have finished another set of adapter mounts using the factory rubber mounts. These give 1/2" clearance under the pan and plenty of room to access the bellhousing bolts.
Riceman83
Eat rice it funds my mk3
Sep 9, 2012
88
Arkansas
Hey hey now,I'm using an ls :) and I can't agree cause most of my factory parts are better than most gen I aftermarket parts...
lowtaco
282
Under a damn Toyota
Only thing the LS engines have going for them is they have an improved runner design and 15 deg valve angle. Take a Gen 1 engine with 18 deg or less heads and it will stomp a LSx.
Yeah ok....
Stock for stock EVERY SINGLE ASPECT of an LS is an improvement to a SBC....
And this is coming from someone that has owned and built SBC's for 30+ years.
Riceman83
Sep 9, 2012
88
Arkansas
I have stock 799 cast heads and they will compare to most aftermarket gen 1 heads of same cc intake runner and still have a better velocity for street use. Step up to the l92 or ls7 design and then your into bbc flow rates. That's just for the basics. The motors as a whole are just build light years ahead of gen 1 design. I'm not here to bash a gen 1 I'm just saying ls are not as you said over rated. If you took the best gen 1 350 design and an equal ls1 and spent the same amount of money on both I would have to say ls would win hands down. Especially in durability.
lowtaco
282
Under a damn Toyota
I understand that the reason for building a new engines is to improve what you have or redesign to make something better. The LS engines are quite a bit better then the Gen1's. The reason I say its overated is because everyone makes it out to be the best engine going, just like the JZ series engines. Nutswingers. I appreciate that the LS is a great design, but dollar for dollar if it was such a great design why is it that racers still build older style/technology motors.
