I'm well over 350 with stock Ignition and non MHG probably over 400 to tell you the truth by now. but maybe not
either way both good engines just go for what best suits you.
IBoughtASupra;1802364 said:The 1JZ or 2JZ is much more stout in stock form. He hasn't stated a power level which I asked for. I choose 400HP out of the blue. Anything higher, a MHG is need.
CPS wires will definitely need to be addressed, probably will need a rebuild. Coils are at least 20+ years old as well as the igniter. You Can argue the same thing about JZ coils BUT stock JZ Toyota replacements work fine.
Why on Earth would you buy stock 7M coils to replace the old one, just do the IS300 UPGRADE.
IBoughtASupra;1802306 said:Cheap: No, not really.
Easy: To get parts, okay that's true. Getting high numbers out of it is not as you will need to upgrade a lot of things. 400HP out of a 1JZ is much much easier than a 7M and its a walk in the park for a 2JZ with its increased stroke. The 7M would need things like its ignition system addressed.
harley1985;1802488 said:i think were forgetting the cost of actually doing the swap? not to mention the 1z or 2z.... for a complete swap your looking at about ??? 4 to 5 grand? now if i dump 5 grand into a 7m? the rite way? thats money... not to mention the aftermarket support for the 7m. is that not a valid point?
IBoughtASupra;1802515 said:OP wants to do a 7M. I'll just support that.
With that said, I am going to be making another thread of the proper way to rebuild/machine 7Ms and talking about write ups, I will be making a few additions to the 1JZ thread soon.
Ian, if you are reading this, be prepared for me to pick the knowledge from your brain!
Ever think it might be people are just getting sick of you jumping into EVERY 7M thread with your 1Jz advice.... Enough already consider this a warning next time you do it you get a week off. :nono:IBoughtASupra;1802546 said:I suggested a JZ swap in the long run as it would hold a lot more power in stock form and hold more than enough power for the street. Then 7M guys had to jump in and assume I was degrading them
If you noticed, I had asked for his:
Power Goal
Tuning Equipment
Mods Already Done
Which still has not been answered.
