S14 KA uses Same flywheel as 7M ??
williamb82
907
4
Tampa, Fl.
PIONEER said:
Allright boys and supragirl. Here's the skinny on the flywheels.
Picture below you will find a Real KA Flywheel from a 95 S14 on the right, and a 7M flywheel on the left. They are not the same. they look similar but the KA flywheel will never mount to a 7M crank b/c the center bore is too small.
supradan22, the N/a and turbo use the same flywheel.
is that crank in the pic good? as in the keyway is straight and the journals are all at std? if so, will you sell it? i need a fully weighted crank for my buildup.
william
figgie
Twin Cities, Minnesot-ah
http://pws.prserv.net/PIONEER/flywheel/DSC00283.JPG
looking at thepicture the KA would not bolt up either. Not because of the center bore> Look at the bolt spacing. THE KA is almost symetrical on the bolts. The 7m is staggered.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
So the new junkyard parts puller employee couldn't tell the difference between a supra and a 240sx and labled the flywheel a KA...... :rofl:
