Running without an innercooler??
Boostedstr8six
I have better SA than you
Near Columbia, the river
TONY! said:
Well...of course a turbo compresses air. I think we all know that.
I meant that the incoming air is heated more from being compressed than from passing through a hot turbocharger.
I would think that most people would have understood me as well.
I pretty much figured that's what you were trying to say. A little clarification never hurt anyone though. :)
Charlie97L said:
air to water run a different system. you have a water tank, pump, lines, a radiator/heat exchanger, and the core. it's a closed system. very good though. i think IJ is using a PWR setup. very stealth.
All depends on the system you buy but Charlie is correct with mine it's a totally self contained unit!
Some of the Drag type systems just use a box that you fill with Water and Ice.
Best analogy I can think of is everyone's played with a bicycle pump and held their finger over the end and pumped...... got hot didn't it? ;)
This is what happens in a Turbo when it's pumping.
