Running shoes
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Now I can't wait for the track. These, plus boost by gear, 100 more WHP's, and antilag should hopefully get me lower than 13.9 @ 124 :nono:
:icon_bigg
Turbo Drifter
534
Surrey, BC Canada
Looks good, those will help I'm sure. It also looks like you just need more seat time to figure out the car if you are running mid 13's and 120+ mph.
I have done 12.2 @119mph with 235/40 18 Kumho SPT's a few times. Was only able to get a 1.9 60' though, I'm sure those new tires of yours will get you better than that.
Good luck!
Jeremy
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
So I actually did end up going to the track tonight. Second time ever. My best was 11.9 @ 120. Not quite sure why my MPH went down but I'm pretty happy.
tissimo
Stock is boring :(
Melbourne, FL
weather maybe? clutch? I know I went to the track ran 12.6 @ 113 on street tires, went back with radials and went 12.4 @ 111 but my clutch wasn't holding the launch (only a 1.98 60' :( ) and was slipping a tad on the top end, I just didn't realize it. Put and old used spec stage 3 in while I RMA'd the first one (didn't try radials again) but was back to 113-114 mph.
Not too bad, what was your 60'
TheNewRed
572
WA
What track do you go too? O, im working in Midilothian for two more weeks, maybe i could see and possibly ride in this beast:naughty:.......
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
thanks guys.. DOH', Justin.. the car was breaking up really bad past 6K RPM's. I was shifting a LOT earlier than normal. Hence the lower MPH. I'm an idiot.
Thenewred- I go to Richmond. Maybe we can meet up while your in town.
60' was 1.70 I believe.. I'll post up the slip :)
disturbed1
372
perth
u will find the drop in mph is more due to the rolling diameter change in rubber.
i ran 118 on normal street tyres yet 115 on mt et raidials
sk6471
Quietly Lurking
May 28, 2005
91
Texas
Good job.:icon_bigg Dollar for dollar, you must have one of the quickest Supras ever. What caused the high end break-up? Not including parts that you couldn't use or have replaced, what has your current set-up cost?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Thanks,
Tuning the car myself helps with saving money because I have many, many hours of tuning time in this setup.
The high RPM break up was caused by the plugs, I'm sure. I recenty swapped out plugs, and wasn't 100% sure what I gapped the old ones to. The other night I took out the plugs and checked the gap, they were .028. I believe I had a brain fart and meant to gap them to .026. Since them I've re-gapped them and that should take care of the breakup I was having.
As far as cost of the total setup, pretty pricey.. I payed more for the clutch than I payed for the car. I'd get out of this car for $10K right now, which I think would be a pretty good deal for someone.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
sk6471;1131522 said:
So, how much did the clutch cost? I'm looking at a HPF feramic clutch with an ACT PP.
roughly $2500 + a push/pull convertor. Had I not wanted to street drive this thing on any backroads I would have put money towards a decent GM auto setup.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Rva;1131585 said:
hey i live in va and i go to richmond drag sometimes hopefully ill see you there the car looks really clean.
Awesome man, yea I'll come find you if I see you there. You wouldn't say it looks clean in person ;). It's dirty but I love it.
frontierguy25
968
TX
Just a question, how come you decided to go with 17" wheels for drag instead of something a little smaller like a 16" or 15"?
