So I've read through a ton of posts, but I can't find exactly what is going wrong with my car. For some reason my car when it starts will usually idle around 1100 rpm, occasionally it will try to idle at the correct 700, but does so really rough and ends up moving between 400-700 rpm. Btw, its a 86.5 w/ 238,000 miles. Also, when this problem started my brakes starting acting up (this may just be a coincidence). The brakes just seem to be loose, but will still lock up. When I hold the gas down in neutral and push the rpm from idle to under 2000 its fine, but once I get over 2000 it will suddenly drop 400-600 rpm and run really rough (like being in 4th at 15 mph). When driving I don't notice this until I sit on the gear (like using engine braking), then you can hear popping sounds and occasional it will jolt. I just recently passed GA emissions and they said everything looked fine on how it was running. My brother who had the Supra before me said it did this and he thinks the mechanic just replaced the egr valve. It averaging 22 mpg on the freeway and 17 in the city if I drive nice, 20-15 if I'm not. Can anyone help me out with this?
I posted this on supraforums, but a friend told me to post this on here.
