im running real rich, i just rebiult me motor, i read some of the other threads about running rich, but i still have some questions, i've heard it could be intercooler pipe leak, maf sensor bad, o2 sensor bad, or knock sensor, so how do i check the code? i cant find anyone with obd1 scanner, and on the drivers side of the motor, there are three spots on the block that you can bolt shit to, i only had 2 when i took the motor apart, are those the knock sensors, and could i have put them in the wrong spot?
