I know its is recommended that when running higher boost that you should have a walbro fuel pump and rc 550's . With this said what will happen if these mods are not made? How much boost is safe to run without these mods?
isnms;1371359 said:I have read that stock fuel pump is only 'reliable' to stock boost level.
I think 8-9psi can be run safely. Some have run more.
I run 8-9 normally with hi boost set on 12-13. I have also had rings destroyed.
I still have stock pump but won't be running higher than 8-9 till I get my mkiv pump installed.
87 supra king;1371802 said:I have a freshly rebuilt motor?
paradox616;1373477 said:now please correct me if im wrong but there is a hatch in the boot you remove to get direct access to the fuel pump...?
i've never removed the pump but i have popped the cap off to take a squiz.
