running issue
1jzmkiii
15
maryland
alright i installed my 1j and for starters this was my first engine swap. im having issues with it running. 1st its misfiring and i have checked almost everything there is to check for a misfire. 2nd it doesnt rev past 2200 rpm without braking up and almost stalling. i checked crank sensor and its working properly. cam sensor connectors had oil in them so i cleaned them out and put them back in but still didnt run right. any other ideas of what i should check? any help would be much appreciated!!!!
1jzmkiii
15
maryland
no the caps in my ecu have not been changed to my knowledge, and i checked plugs, crank sensor, and voltage coming out of igniter... im not sure how to check the coils, so that could be the problem. bad news is while doing a compression check last night one of the coils had an internal short and fried itself. so that was probably causing the misfire but what about the revving issue?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
bobiseverywhere said:
annoyingrob
What is the part number for those connectors do you know it?
I don't know the part number, but you can get the 2JZ coil connectors at the dealership. They're a new design over the 1JZ ones, and clip in much tighter. Plus, all 6 are <$50
