Rough idle & acceleration. Codes 24, 34, 42 & 52...
7M4EVR
695
fah, fah away
Hmm. With the hot intake temps i got and sluggish pull im certain i got boost leaks again. Briefly can u describe how a boost leak could make more air flow past the afm? It should just let more air out of the system not affect how much air the afm sees or am I way off?
Boost leak is after the turbo. So when your leaking air the turbo is spooling up more because the wastegate is not opening and sucking more air past the afm.
7M4EVR
695
fah, fah away
Thank u..that makes sense now.
7M4EVR
695
fah, fah away
Turned out to be a couple boost leaks. Pulls like a freight tain now. Only problem now is during wot at the top of the rpm range the vf signal goes full lean. At any other time my vf is perfect. I thought i remembered reading a while back that vf doesnt monitor open loop so maybe im alright? In any event i should be hooking up the wideband today to see how its looking. The safc might not even be needed i feel like
