roof side ventilator louver is glossy!
Oct 11, 2005
3,819
20
Thousand Oaks, CA
The plastic appears to be painted gloss black. Given that, is the plastic polish still the right stuff to use?
GrimJack said:
McGuires plastic polish should get them back to new condition pretty easily, as long as they aren't cracked.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Hey 88mkIIIproject what is up with all the double posting? Use the edit button. I have looked in a few threads and you are double posting everywhere.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
LOL - I guess he annoyed someone else with that, too, notice his post count seems to have dropped dramatically.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
89turbotoy said:
mine are still glossy but the pass side is kinda loose. gotta fix that.
There are two nuts that hold these things on from the backside. If they are loose you need to pull the trim off the inside and retighten them. Its quite a bit of work as the seat belt guide and other stuff needs to come off as well.
there are 2 studs and a clip in the middle. Clip usualy falls apart, and the part itself will eventually start to crack down the center.
