Poodles;1238178 said:I'll second the comment about adjusting idle as there isn't any way to do it properly (idle is controlled through the idle control, not the throttlebody)
quick questions on this screw (I still I have much to learn):
A. why is it on the motor if it is not supposed to be used? Emergency situation, like if something breaks adjusting it will get you home or?
B. What if you have fucked with it not knowing you were not supposed to, what is the factory setting (where is it supposed to be)?
C. No matter what you do with the screw, is the computer supposed to adjust and reset the idle anyway (mine has stayed low after adjusting it down to 650rpms...)
Not trying to jack just adding to the conversation, OP might be curious to know the answers also...
