Roll Cages?
Came over a crest on a divided road to find some Gumby in a roadworks machine doing an illeagal U turn across the centre divider, I was going a little quick at the time headed for an escape route car spun and reversed into a concrete pole.
If it weren't for the Cage I'd have been killed outright, the EMS guys praised how strong the car was built I even had the presence of mind to kill the battery power before impact. (Isolator between the seats next to the MBC and brake balance)
dbsupra90
toonar
indiucky
damn IJ! i saw pics of it on your build. i had no idea it met such a demise. you must have been going "quick". it hit the pole so hard the steering wheel ended up on the passenger side! ;)
jawsgear
Undergoing Construction
Jan 29, 2006
465
Sactown
www.jawsgear.com
SW Cage can work but is a crapload of work to make it fit. I did a through dash kit on my car and not one piece was the correct bend or angle. Took almost 3 solid days of just welding, bending, cutting, and notching. Good luck.
Oh by the way roll bar & back seat passengers :nuts:
