rodknock, how can you tell
RPSil13
464
Anaheim, CA
so im having an issue w/ my supra, after driving the car for a bit (10-15 min) at operating temp and i come to a stop sign, my idle drops to about 700 and i can hear a sound coming from the engine, it sounds like theres a marble in the oilpan, but i lightly put my foot on the gass and bring the rpms to 1000 the noise goes completely away, i thought it could have something to do w/ the timing and the timing is at 15 BTDC, iirc its supposed to be at 10-12BTDC, does this sound like its developing rodknock, is there a way to check/test for rodknock
thanks
any help would be appreciated.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Use one of those stethescopes, listen to the side of the block while it is running (on a lift or something to that effect..) You should be able to pinpoint the location of the noise by doing this.
RPSil13
464
Anaheim, CA
GrimJack;1344305 said:
When you can hear the noise, simply pull the plug wires one at a time.
If one of the wires makes the noise go away, that rod's bearings are toast.
i will try this method, thanks,
