:wtf:Was the block line bored? Its possible the crank moved upwards into the block enough from a line bore to set all the rods closer to the block? Just a shot in the dark
CyFi6;1688815 said::wtf:Was the block line bored? Its possible the crank moved upwards into the block enough from a line bore to set all the rods closer to the block? Just a shot in the dark
IBoughtASupra;1688818 said:That block would have had some serious material taken off.
CyFi6;1688840 said:Well when they line bore it they remove material in order to make it round and original size again, essentially moving the crankshaft up into the block. Considering you have a 100% stock bottom end as far as crank and rods are concerned and you are still hitting, something has changed. I would be inclined to figure out what it is before clearancing the block but that is just me. Even with a reground crank and the use of undersize bearings everything should sit in the same position it did from the facrtory. I also wouldn't be grinding anything without fully taking it apart.
