That doesn't sound like rod knock to me...unless every single rod bearing is bad...but usually it is just one it seems.
I would check the crank pulley and make sure it isn't loose, check all the obvious things like the fan etc, it could even be clutch related or bad bearings in the water pump or alternator...
Just my .02
Also, how is your oil pressure? I'd imagine it would be quite low if it were rod bearings.
Just my .02
