Rod knock or noisy head?
radiod
1,342
Abbotsford, BC
Piston slap is the sounds of the piston skirt slapping the side of the cylinder wall when moving up and/or down. It's caused by the cylinder walls being slightly oversized for the piston inside. It's much more noticeable on a cold engine because as the engine warms up the piston has a tendency to expand and the fit in the cylinder is better. It can sound very similar to rod knock.
mk3-4-me
669
Milwaukee, WI
Wow... Maybe that's it? Idk I'm just ettin excited now cause that very well could be it... But idk if I should be getting excited cause idk if Thats alright or not.. Lol
I did hone my cylinders, so I obviously took some away makin it slightly bigger. So do you think its that? Stock piston size.
Is that bad for the pistons / cylinders? Can I get away with it for a lil bit if it is?
And how would you go about figuring if it's this or RK?
mk3-4-me
669
Milwaukee, WI
Ya I'm almost 100% it's RK... Luke I said I'll try to get a video up after I'm done working.
I guess it's time for a 500+ hp build. At least I can lookforward to that now...
This sums though I Just got it runnin and registered.. :(
Idk wat the hell happened.. But I cnt do anything now.
Thx for the help and sry for postin another stupid RK tread... Lol
Thx
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Furthermore, I am not trying to insult you, but you replaced all the bearings. If you do in fact have rod knock (which hasn't been confirmed), its because you did something wrong when rebuilding. Considering you dont know whats wrong, taking it apart again and trying to make it make 500+ hp is the last thing you should be trying.
mk3-4-me
669
Milwaukee, WI
I am gunna put a video up after I'm done working.
And yes I know I must of messed up somewhere, but that's how you learn isn't it? That was the first time I have ever worked with a 7m, and I was rebuildin it. Lol I am gunna rebuild it cause now I know what to do and check for.
And I dnt take it as an insult but rather you trying to help me! Lol so thx
But ya I will get q vid up at like 6ish.
mk3-4-me
669
Milwaukee, WI
how do you know what to do and check for if you don't know what you did wrong in the first place?
I guess u got me there. Lol but Idc it's still fun to rebuild motors. And I'll have a better chance of not having rod knock if rebuild it rather than leaving it sit... Lol.
I'll just be more careful I guess...
mk3-4-me
669
Milwaukee, WI
[video]http://gfx1.hotmail.com/mail/w4/pr04/ltr/at48/video.png[/video]
ok i tried to post a video.. idk if itll work its my first time with a video.
but if it does work youll hear the noise in between the fan air noise.
---------- Post added at 06:04 PM ---------- Previous post was at 06:04 PM ----------
no i just stried it doesnt work.
i have it on my iphone, how should i do it?
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
then the second time around do everything carefully, take your time, and do a lot of research... especially if you want higher hp #'s...
dont overlook anything and dont skimp out on anything.
Turbo Habanero
4,229
Tucson,AZ
if you have a iphone create a youtube acount and upload from your phone straight to youtube through youtube app. or the same with photobucket
radiod
1,342
Abbotsford, BC
Your link wasn't working for me, so I modified it for simplicity for other users ;)
http://www.youtube.com/watch?v=EcPG52ezGyw
I'd double check all your bolts mentioned already as well as the cam gear bolts. What RPM were you running that at? How warm was the engine? Does it make the same noises at half or twice the rpm it was running in the video?
mk3-4-me
669
Milwaukee, WI
Ya I was gunna say that the video was when i started it up, so it was at around 2100ish rpm.
So it was a cold engine and that's the only rpm that I've noticed it at so far..
