rod and main bearings
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
So if I messed up a bearing because of bhg,and my goal is 450-500 would the Titan clevite ones be ok? Fwiw I have wiseco pistons on crower rods
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
should be fine as long as you assemble correctly with the correct size bearings and ensure proper clearances and that the surfaces are not damaged.
grimreaper
2,180
Dallas
giterboosted;1535796 said:
How would I go about ordering the correct sizes? All it said at Titan was regular or +25 if I remember correctly
you shouldn't order bearings until the machine shop measures the crank. Once thats done, they will tell you what size to get.
