Roadboy's 350hp build
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Nice to see another local guy on here. I haven't seen you in person driving around yet. The build looks good, although i'm dumbfounded why you could not find the bolts to mount the block to an engine stand easily. I took maybe 10 mins finding mine at the time (gr.12 fasteners ;)).
Good luck, and I hope to see it in person sometime.
Where in T.O are you?
eric
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
WhtMa71:
Thanks, im still looking for cams vs a bigger turbo, maybe ill go for both, who knows till i finish most of the build.
Guyana00:
i havent been to the meets yet, been busy fixing my car.
92nsx:
i have seen smaller cams, was regrinds 254? or something by ted or toda, (Something like that)
it states it has gains over to 7k but after that it loses power, while the Mine's ecu cuts the rev to about 8k-9k+ iirc.
i dont know what else im looking at, if i get a bigger turbo ill need a walbro, lex and 550 plus tuning.
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
eric
Hey, well i haven't been to the meets before, other than pur automotive , but wasn't driving my car. the bolts were....jst hard to find, it wasn't the right length so i jst went to toyota and got them. i hope to see your car sometime as well or maybe at the meets if you go there. im more up north than in Toronto, located in Markham/stouffville
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
update:
i ordered mk3 seat brackets and just got MOMO bucket seats yesterday for 250 for the pair.
currently started painted the block black (ceramic) and also sanding my white bumper and waiting for the paint to come.
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
update:
got my seat brackets that go with the momo seats, also acquired a 3" adapter to hook up my amsoil air filter, apparently it has a hks one and it didn't fit because of the lip. also got a full 3" SS elbow, apparently mine was stock.
i also ordered from DM:
arp rod bolts
arp flywheel bolts
new timing idler
engine gasket set
My new goals are:
GReddy 20G turbo or ct26(57trim)
BC 264 or regrind cams
spearco or replica intercooler
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
heres some pics:
ARP flywheel bolts
ARP Rod bolts
Gasket set (yes i know they are the same,there was a error, bottom end coming soon)
im hoping everything will be done before december or the middle of december.
Project 1 - currently still sanding my white bumper (almost there, i had to bondo parts and needed to fill holes, you will see why later when its done)
Project 2 - building my bottom end 7mgte. going to be all stock bottom end with BC 264 or regrinds.
Project 3 - hooking up a GReddy catch can, just looking for -8ans hose (1/2) so i can tee it off at the throttle and intake.
List:
Spearco style intercooler $160
BC cams or regrinds - $200 - 700
Paint - $100
Transmission fluid change (mt90) - $80
Brake rotor and pads - $120
Drill holes on pedals for MOMO pedals - Free
Side Skirts - $150
TOTAL:
$610 without Cams
Not sure if i should get a bigger turbo, i want to see what i am pulling first. if i am at the 300 range without cams yet, i will only get cams.
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
sanding down this white bumper right now.
Today i had some time before my exam, so i plastigage'd it yesterday good clearance. all within spec ,today i put on the bearings, lubed it up and torqued it down good. and spins freely. just waiting on my rods so i can bore them with arp's.
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
so my cars finally done, done building the bottom end, its in the trunk also ordered some parts
its going to the shop tomorrow
Exedy clutch
upper hardpipe
lex afm
AEM wideband
new stuff soon:
550cc
intercooler
BODY WORK
i have pictures of the block i will post them up soon
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
soo i dont have any pics of the parts, but i will soon. heres the pics of the supra on the flatbed.
anyways update i finially found 550cc injectors, now i can install them with my lex afm.
paradox616
472
Melbourne, Australia
Looks good! you don't need cams to get 400rwhp... installing cams will change the entire profile of the motor so if you do make sure you do your homework.
Good luck with the build
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
SUROKO- thanks, yea long time no talk, hows your supra doing?
black89t;1572425 said:
lookin good.
where did you get the brake set-up?
i got it on supraforums, through a guy. it was 100 for a front setup. i got drilled roters through a guy on ebay (yes ebay) but it had warranty (tutuauto) wouldent recommend the pads, but it comes free. anyways i got it for my tsx for $175cad around 160usd? but they come with warranty and everything so i went this way and tried for the tsx.
paradox616-Thanks, about the cams, im not going to go with bigger cams, iv changed my mod sheet, just havent posted it up yet.
anyways.....i found out a few houses away theres a white pre 89 supra!! and the guy just got it. so the mechanic said the car will be done by next week. this weekend im going to be helping out with the swap, hope everything goes well!!
northwestsupra
1,166
Washington, Marysville
just my word of advice, i'd really figure out the turbo your going to go with, and stick to it or else you will be like me and build an engine to support a gt-45 turbo and then end up noticing your goals are just way to rediculous for your budget then you will find yourself selling parts that you just bought, but yet in the end im happy because i know my engine could support a gt-45 even though im only running a simple t-70 :p and even though im still building mine and went from 550cc inj. lex afm dual walbro, to 880cc inj. full areomotive setup and a1000 pump and just rediculous everything i know ill be safe, but i also messed up by not just getting a stand alone right away lol. i will say now turbo and standalone. or in your case mines ecu. would be the most expensive things on my list of parts i've gotten so far. but personally dont waste your money on looks, get to your goal, make it work. then work on the other aspects, safety/suspension/looks.. but looks good so far, hope you dont get pulled over like i did for the tinted tail lights lol. i got busted almost everyday when i was in high school for them.
roadboy
Supra Owner
Jan 22, 2008
456
Toronto, Ontario
Thanks everyone, especially on the advice. anyways last two weeks were painful for me, but i have learned alot of stuff about the supra.
so today i put back the exhaust and everything else, first run, leaked oil and fuel!!
oil was leaking under the oil filter housing, the plate, and fuel was leaking because i used a metal washer instead of copper
took about an hour to fix everything, double checked and started the second time. everything checked out runs good
but the alternator went out on me, so tomorrow im going to change the alternator and i can start driving again!!
CLIFFS: has oil and fuel leak, fixed it up and its running again, but gotta replace the alternator
here are some pictures of the process of the swap.
new injectors:
engine coming out
Engine finally out
my exhaust system
yea my bumpers messed, still havent painted anything on my new bumper yet.
my blown turbo
i do love shiney things =D
